2005 Infiniti I30 Service Eng Soon Warning Light in dash
2005 INFINITI I30
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
JABE
I just bought this car used - and when the check eng light come on and did not go out I took it to the dealer for repair - they said the intake solenoid was clogged and that the oil needed to be changed freq to prevent - after about 2,500 more miles I got the same and took it back to the dealer - this time they flushed the system and replaced both intake solenoids saying it was the same problem - after about 2,000 more miles I got the light again and took it in to a oil change place, had them flush the system and after about a day or so the light went out - another 2,000 miles and the I have the light on again - it does not blink it is just on solid - I checked the gas cap and the air filter and tried holding down the pedal for 10 sec to reset but still on and values do not sound right - do I really need to change oil every 2000 miles to avoid this?
Mar 18, 2008 at 4:41 PM
SERVICE WRITER
  • 9,123 POSTS
What code number is being listed right now?
Mar 18, 2008 at 5:43 PM
BMRFIXIT
  • 19,053 POSTS
next time you have the light come on have it scanned for codes (most local part store will do it for free )
and post the code s
for more help
and is it check engine light that is on or maintenance required
let me know
Mar 18, 2008 at 7:03 PM
JABE
[quote:37ae6d0a61="jabe"]Computer problem
2005 Infiniti I30 6 cyl Two Wheel Drive Automatic 88000 miles
I just bought this car used - and when the check eng light come on and did not go out I took it to the dealer for repair - they said the intake solenoid was clogged and that the oil needed to be changed freq to prevent - after about 2,500 more miles I got the same and took it back to the dealer - this time they flushed the system and replaced both intake solenoids saying it was the same problem - after about 2,000 more miles I got the light again and took it in to a oil change place, had them flush the system and after about a day or so the light went out - another 2,000 miles and the I have the light on again - it does not blink it is just on solid - I checked the gas cap and the air filter and tried holding down the pedal for 10 sec to reset but still on and values do not sound right - do I really need to change oil every 2000 miles to avoid this?[/quote:37ae6d0a61]
Hello- this is the "Service Engine Soon" light in the dash - Owners Manual says could be loose gas cap but I checked that and I took it in the dealer twice for this problem and both times they said clogged intake solenoids and it cost me a fortune to replace - I will get the code on this and advise. Tks,
Mar 18, 2008 at 10:40 PM
