2000 Infiniti I30 3 Way Catalytic Converter
2000 INFINITI I30
141,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARSENIC
My check engine light came on some time ago. I took my car to the shop and found out that my 3-way catalytic converter has failed and that I need to get it replaced.After some research, I found out my car has more than one catalytic converter. (supposedly it has a front catalytic converter and a rear catalytic converter ????). My question is, Which one is the 3-way catalytic converter? Do I need the front converter or the rear converter replaced? Or does the term 3-way catalytic converter refer to both catalytic converters as a whole?
Oct 11, 2009 at 12:36 PM
DOCFIXIT
  • 18,828 POSTS
one CAT for each bank of engine. if you can provide code in P0xxx format I can tell you which one
Oct 14, 2009 at 3:03 PM
