1999 Infiniti I30 Changing the struts
1999 INFINITI I30
147,000 MILES • 6 CYL • FWD • AUTOMATIC
RLGUARIG
I have a reasonable amount of experience twisting a wrench and a pretty good selection of tools. What do I need to know about changing the struts on this car, other than the need for the spring compression tool? Your help and advice are greatly appreciated.
Jan 10, 2009 at 12:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
To remove the strut assembly on your I30, perform the following.
REMOVAL:
Support transverse link to remove tension from strut mount nuts and bolts.
Remove upper and lower strut mount nuts and bolts.
Do NOT remove pistion rod lock nut at this time.
Remove strut assembly.
DISASSEMBLY:
Clamp strut in vise, using Vise Attachment (ST35652000). Loosen, but DO NOT remove, piston rod lock nut.
Compress coil spring with Spring Compressor (HT71780000).
Remove piston rod lock nut.
Remove coil spring.
REASSEMBLY:
Be careful to install spring correctly. Top end is flat.
Install upper spring seat with notch facing outer side of vehicle.
Install piston rod lock nut and tighten to 44 - 55 Ft. Lbs. (59 - 74 Nm)
INSTALLATION:
To install, reverse removal pocedure.
If you need further assistance with this procedure, just let me know.
Hope this helps..
Thanks for using 2carpros.com !
Jan 10, 2009 at 3:42 PM
