1998 Infiniti I30 how to replace telescope antenna mast
1998 INFINITI I30
TM023
1998 Infiniti I30 6 cyl Front Wheel Drive Automatic
My antenna mast broke. What are the steps to take to replace it if I purchase a new one. The motor is fine just the telescope part broke.
Jun 3, 2009 at 6:35 PM
IMPALASS
  • 3,112 POSTS
Hello - I think this is what you are asking for. ANTENNA ROD Removal 1. Remove antenna nut and antenna base. See Fig. 3 .
https://www.2carpros.com/forum/automotive_pictures/248015_f3_3.jpg
2. Withdraw antenna rod while raising it by operating antenna motor. See Fig. 4 .
https://www.2carpros.com/forum/automotive_pictures/248015_f4_2.jpg
Fig. 3: Removing Antenna Nut & Base Fig. 4: Removing Antenna Rod Installation 1. Lower antenna rod by operating antenna motor. 2. Insert gear section of antenna rope into place with it facing toward antenna motor. See Fig. 5 .
https://www.2carpros.com/forum/automotive_pictures/248015_f5_2.jpg
3. As soon as antenna rope is wound on antenna motor, stop antenna motor. Insert antenna rod lower end into antenna motor pipe. 4. Retract antenna rod completely by operating antenna motor. 5. Install antenna nut and base. Fig. 5: Installing Antenna Rod
Jun 3, 2009 at 10:43 PM
BTEK
How do you stop the antenna motor after the line is reeled in? My problem with these directions is that after the line is retracted and the antenna is fully extended, it seems as though the antenna is completely reeled out an it does not get reeled in again. Is there a way to stop it as soon as it fully extends so it never goes past the point to unreel the line any further? Thank you.
Jun 20, 2010 at 9:05 AM
