1997 Infiniti I30 Stuck in 3th gear
1997 INFINITI I30
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
GIBBONSL
  • 4 POSTS
I have a 1997 ihfinite i30 with automatic transmission but it start up in grear and will not change I manuel put it in 1 no change 2 no change I put it in drive it start slow but catch up fast and then I just float along with the speedometer saying 80-85 with my RPM at 4 Is my transmission gone. oh yeah my check engine light is on and reverse work good how can i fix this
Mar 7, 2008 at 2:27 PM
MASTERTECHTIM
  • 4,750 POSTS
dont panic. first of all stop driving vehicle around. have the computer scanned for codes, autozone will do this for free. you might just have a bad speed sensor causing the transmission to go into failsafe, this is normal. get back to us after you have the codes.
Mar 7, 2008 at 2:33 PM
Get these sensors checked out coolant temperature/throttle position/vehicle speed sensors -it inputs signals to the computer as an indications of throttle/governor pressures and overdrive in a given temp. -and in turn commands the transmission solenoids to upshift/downshift/lock-up and so on-
Sensors ruled out-get the transmission pressure tested to identify internal problems.
GIBBONSL
  • 4 POSTS
[quote:216e07143d="mastertechtim"]dont panic. first of all stop driving vehicle around. have the computer scanned for codes, autozone will do this for free. you might just have a bad speed sensor causing the transmission to go into failsafe, this is normal. get back to us after you have the codes.[/quote:216e07143d]
P0110
po325 Low fuel pressure
P1605
P0600
Mar 12, 2008 at 11:47 AM
1605 internal communication problem with the TCM and ECM.
P0110 an intake air temperature sensor problem
P0600 communication link error.
Double check the battery connection-and wiring to the transmission-might want to rescan the transmission control module.
Mar 12, 2008 at 4:42 PM
