1996 Infiniti I30 no ground to fuel injectors
1996 INFINITI I30
SNOOKER
Engine problem
1996 Infiniti I30 6 cyl Front Wheel Drive Automatic 200k miles
car will crank but won't start.
sprayed thrust into intake & it runs for a short while.
removed injector#1 & I'm getting fuel to the rail.
checked for +12volts @ the injector plug...got +12 but no ground trigger.
With the #1 injector removed, I ran a wire from the neg. Batt. term. & the injector clicked.
Do I have a bad computer or is it something else??
any help would be greatly appreciated!
Thank-you,
Bob
Jan 14, 2008 at 7:42 AM
SNOOKER
Changed out the ECU & it Starts!!
Bob
Jan 15, 2008 at 7:42 AM
SNOOKER
Codes P1336 & P0335??
Jan 16, 2008 at 8:55 AM
