2007 Infiniti G35 surges
2007 INFINITI G35
PBLUMAN
Engine Performance problem
2007 Infiniti G35 6 cyl All Wheel Drive 33000 miles
When I take off from a stop, the car power surges then drops , sometimes dangerously as I get less power as I enter traffic.
Mar 21, 2010 at 11:42 AM
Hi pbluman, Welcome to 2carpros and TY for the donation
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 22, 2010 at 5:35 AM
KEN08041987
I am having the same problem. I have noticed it when I start from a stop and the engine is relatively cold (first 5 minutes or so) or if barely pressing accelerator on highway. If i put the hammer down it goes away. Interested in answer as my dealership wants major $$$ everytime I go in there.
Feb 27, 2013 at 1:41 PM
