2006 Infiniti G35 Suspension, brakes or something else
2006 INFINITI G35
43,600 MILES • 6 CYL • AWD • AUTOMATIC
DBJDPB
I have an 06 G35 AWD and purchased it used recently. There are a few minor signs that it might have been in a bump up and never recorded as such but I cannot be certain. At any rate, the vehcile handles well and does well but one thing bothers me. Often upon starting out it makes an annoying creaking noise that seems to come underneath, passenger side front when initially braking or hitting minor bumps. Sometimes it seems to come mid to rear but most often the passenger front. I don't notice it when drivng normally after starting although it may do it occasionally. It just creaks and I have had one shop look and could not find anything. They stated that they lubricated the bushings but it did not resolve the issue. Any thoughts?[img:764f60ded3]http://www.2carpros.com/forum/automotive_pictures/453457_Infiniti_1.jpg[/img:764f60ded3]
Dec 25, 2009 at 1:12 PM
IMPALASS
  • 3,112 POSTS
Hello –
To assist you better is your model just the G35 or G35x and what is your engine size in liter?
Dec 25, 2009 at 4:31 PM
DBJDPB
It is a 3.5 Liter 6 cyl and I believe it to be an X. It is AWD. The creak is the best description of the sound and often times it seems related to braking.
Dec 25, 2009 at 4:52 PM
IMPALASS
  • 3,112 POSTS
Hello –
First, congrats on your new car………..very nice looking.
Next, try checking CarFax below and that should tell you the history on the car.
Okay………what it may be is the compression rod. Below is a pic of it. There is a Technical Service bulletin on “NOISE FROM FRONT COMPRESSION ROD” This may be the problem.
https://www.2carpros.com/forum/automotive_pictures/248015_1_190.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_Picture1_106.jpg
https://www.2carpros.com/forum/automotive_pictures/248015_Picture2_68.jpg
TECHNICAL SERVICE BULLETIN
Reference Number(s): ITB08-013, Date of Issue: March 10, 2008
INFINITI: 2004 - 2006 G35 Coupe; 2004 - 2006 G35 Sedan
CLASSIFICATION: FA08-001
APPLIED VEHICLES: 2004 - 2006 G35 Coupe (CV35); 2004 - 2006 G35 Sedan (V35)
Related Ref Number(s): ITB08-013
ARTICLE BEGINNING
IF YOU CONFIRM
There is a noise coming from the front compression rod.
And
The bushing is damaged.
ACTIONS
Replace only the bushing, not the compression rod assy. for this issue.
I would have the shop you took it to check out this TSB to see if this is the problem and then if it is refer to the TSB for the repair.
If that isn’t it let me know and we will try to look at other things.
Dec 26, 2009 at 1:01 AM
