2004 Infiniti G35 no heat
2004 INFINITI G35
31,000 MILES • 6 CYL • AWD • AUTOMATIC
WALLYGATOR
when you try to set the internal temp for heat
both the inside temp and the setting temp scroll
up and down with the same number , unless there is a mismatch calling for heat it will not come on
Dec 8, 2008 at 3:40 PM
MMPRINCE4000
  • 8,548 POSTS
If the engine was not getting to normal operating temp, you should be getting an error code.
So it is more than likely the temp control module.
This is probably going to have to go to dealer service unless you can find an Infinity service garage locally.
Dec 9, 2008 at 8:56 AM
