Electrical problem
2003 Infiniti G35 6 cyl Two Wheel Drive Automatic
when i changed the oil and air filter the check engine light came on. not flashing but constant. i put in a k&n air filter could this cause this problem. I sprayed throttle body cleaner on butterfly (i disassembled everything first) then reset codes. it worked for 2 days then came back on.
Aug 22, 2010 at 8:14 PM
