Turn signals stopped working
2001 INFINITI G20
162,000 MILES • 4 CYL • FWD • AUTOMATIC
JPSM1TH
My turn signals have stopped working and so has my hazard switch. It seemed like a gradual failing of something electrical because it stopped for a little, then came back, then it stopped permanently. I know it is not a housing connection problem because they still flash when I lock my car remotely, therefore it is not the bulbs either. I have checked my fuses and they are fine. I was told told to check my relays but I have no idea how to do so, so if that is your suggestion, where can I find them on my car? Your help is greatly appreciated.
Dec 13, 2009 at 1:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It sounds like the flasher unit is not working right, but to be sure here is a guide to help you test for power to see where you are losing it and the blinker wiring diagrams so you can see how the system works:
They call it a combination flasher.
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Dec 13, 2009 at 7:58 PM
SILVER WOLF
I had this problem and checked things out using these guides and diagrams the flasher fixed it.
Jun 20, 2018 at 1:58 PM
