1. Close and lock all doors. Erase original identity code(s) by inserting and removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice. Turn ignition switch to ACC position. 2. Push any button on new remote controller once. Hazard warning lights should flash twice, indicating ID code has been entered. If identity code cannot be entered, repair multi-remote system. 3. For each additional remote controller to be programmed, manually release door lock, and lock again by using door panel switch and repeat step 2 . If no additional remote controllers are to be used, exit programming mode by unlocking and opening driver's door. NOTE: A maximum of 4 remote controllers can be programmed. Any attempt to program more than 4 controllers will be ignored. If same identity code is entered more than once, entry is ignored even though hazard warning lights will still flash twice.
ALL REMOTE CONTROLLER FUNCTIONS INOPERATIVE Perform the following diagnostic procedures: REMOTE CONTROLLER BATTERY CHECK , KEY SWITCH CHECK , DOOR SWITCH CHECK and POWER SUPPLY & GROUND CIRCUIT CHECKS under SYSTEM TESTS. Also, check remote controller function, perform PROGRAMMING NEW ID CODE procedure under PROGRAMMING REMOTE CONTROLLER.
Mar 12, 2010 at 1:38 PM
