1999 Infiniti G20 engine stalled
1999 INFINITI G20
177,000 MILES • 4 CYL • FWD • AUTOMATIC
JAMES MCCAULEY
Engine stalled slowly while driving on interstate. Got a knock sensor trouble code at autozone. I have fuel & spark. The engine turns over, the rotor turns & has fire. I have pulse to the injectors. What else should I check? What might the problem be?
Oct 14, 2010 at 5:22 PM
Hi james Mccauley, Welcome to 2carpros and TY for the donation
Check the fuel pressure if its within specs-
Fuel PressureWith Regulator Vacuum Hose Connected 235 kPa (34 psi)
With Regulator Vacuum Hose Disconnected 294 kPa (43 psi)
Oct 14, 2010 at 10:32 PM
