I have an 1993.5 infiniti g20 when i first got it i had to replace the engine. replaced with engine that was manual...
I am having the issue with my car where it acts like it doesnt know when to shift; I have also noticed when going down the road I feel the wheel wiggle left and right about 0-40mph. i know i need an alignment it pulls to the right.
It has the A/T Switch where you can switch between Power and Comfort Modes; I leave it on auto. Sometimes when it needs to shift the light comes on for a split second like a flicker, when i start the car i do know it needs to have that light turn on to signal good to go but it mostly just blinks about 16 times. I try to restart the engine but usually is the same. Also sometimes when i stop it luggs and just dies. It usually works fine about 40mph and above...Runs great when its not in fail-safe mode.
We replaced the VSS-Vehicle Speed Sensor, Drained the system, We have even reset the ECU (when i reset the computer it did blink a code but i think it was before the engine was replaced blinked 34 code; Which is Knock Sensor. which i cleared.
i have done the onboard diagnostics without consult and it has to do the 10 blinks it, It has done 2 different ones at couple different times:
X-0-0-0-0-0-0-0-0-0-0 and X-X-0-0-0-0-0-0-0-0
The OD light does not blink at all, SES check engine light is not on.
I have the FSM for a 1994 infiniti g20
Jan 31, 2010 at 9:06 PM
