1992 Infiniti G20 How to remove driveshaft?
1992 INFINITI G20
130,000 MILES • 4 CYL • FWD • AUTOMATIC
THESLAGLES
I am removing my engine/transmission and I can not pull the engine out because I can't figure out how to remove the driveshaft/axle in order to pull it out? What do I need to do to continue removing my engine/transmission?
Feb 19, 2008 at 2:08 PM
GLEN C
  • 10 POSTS
you need to jack up, block .remove tires, disconnect lower ball joints ( or rermove a-arm bolts ) . disconnect tierods, remove cotter pin, keeper & nut on outside of axle, jack up on front spindel( brake rotor) moving it out ward, pull axle out of front spindle from behind,put bucket under trans to catch oil( drivers side) , pull sharply on axle and will come out.Similar on passenger side.
Apr 12, 2008 at 4:29 PM
