Hello once again.
Here is the actual test procedure for that code for your car:
B6/1 (Camshaft Hall sensor)
Check component B6/1 (Camshaft Hall sensor).
Test 1 Check Actual Value B6/1 (Camshaft Hall sensor)
Test 2 Test Voltage Supply of Component B6/1 (Camshaft Hall Sensor)
Test 3 Test Signal Voltage of Component B6/1 (Camshaft Hall Sensor)
Test requirement
- Carry out measurement with engine running.
Status of relevant actual value:
- B6/1 (Camshaft Hall sensor): Note! Communication with ECM required.
Specified value
- [SIGNAL PRESENT]
Question
- Is the actual value o.k.?
Yes
The actual value is okay. ** End of Test **
No
The actual value is not o.k.
Possible cause and remedy
- Test voltage supply of component B6/1 (Camshaft Hall sensor).
- Leads to component B6/1 (Camshaft Hall sensor)
- Component B6/1 (Camshaft Hall sensor)
** End of Test **
Test requirement
- The actual value is not o.k.
Test sequence
- Switch off ignition.
- Detach the socket at the component B6/1 (Camshaft Hall sensor).
- (B6/1) 1 3 (B6/1)
- Switch on ignition.
Specified value
- Voltage[11.0...14.5] V
Question
- Is the measured value okay?
Yes
The measured value is o.k.
- Signal wire
No
The measured value is not o.k.
- K40/7f29 (Fuse 29)
** End of Test **
Test requirement
Test sequence
- Connection Measuring system
- A4 Blue socket Green socket A7
- Operate engine at idling speed.
Specified value
- Measuring system
Note
- Measuring system:Continue with key F2
Note
- Measuring system HMS990 integrated in STAR DIAGNOSIS, is required for performing the next test step.Switch on measuring system HMS990 for this step.Continue with key F3
- If measuring system HMS990 is not integrated in your STAR DIAGNOSIS, it is also possible to carry out the next tests with alternative measuring equipment such as oscilloscope, pressure gage or digital multi-meter. Continue with key F4
Question
- Is measuring system HMS990 to be started?
Question
Yes
The measured value is o.k. ** End of Test **
No
- Signal wire
** End of Test **
As you can see there should be voltage on 2 wires, one should be around battery voltage (supply) the other should be around 5 volts (signal). The battery voltage circuit also supplies the fuel injectors and a lot of other components of the system so if you don't have the voltage present it will not run. I would start there and make sure you have voltage, making sure the fuse specified in the test is good.
If you do have the voltage as specified then you will have to do as you stated and back track until you find the issue. In my experience the most common issue in a situation like this is a missed ground so pay close attention to them and make sure they are properly attached and tightened.
As always we will be very interested in your progress so please keep us up to date and thank you for using 2CarPros!
Jul 27, 2020 at 5:03 AM
