I need a better picture of where the inertia switch is located please.maybe not a better picture but one more picture detailed.please
Apr 30, 2020 at 6:25 AM
CERTIFIED EXPERT
Good morning,
There is no inertia switch for the fuel pump if that is what you are asking. That is for Fords only.
You have a relay. I attached a diagram of the fuel pump for you to view.
What is the issue with the truck?
Apr 30, 2020 at 7:16 AM
SHELBIE KADIVA
MEMBER
Are you ready for this? Okay, my boyfriend broke the key off in the ignition my dad took a pic to try to pick out the broken key and pulled the key forward a little bit which made the electric or the security alarm system go off and so he got that stuck in the ignition. So a friend of mine cut the starter and ignition wires connected them to make a toggle switch and a push button. then my dad went and put the wires back took the push button and toggle away and then got the key out we raised the key to a different key broken key so it's usable key at this point. It actually is turning the car over but not starting. the only thing I could think of is left to do is something to do with the fuel. I'm not a mechanic and I'm doing this pretty much on my own.
Apr 30, 2020 at 7:31 AM
CERTIFIED EXPERT
Okay, is there a security light, theft light or a key signal on the dash?
