If it starts to work when you wiggle it, I suspect the switch itself it bad. This is an easy one to replace, so you may want to at least check it to make sure there are no loose connectors, damaged wires or any obvious issues.
You mentioned you hear a strange noise. My concern is there is a short in the switch.
Here are the directions. The attached picture correlates with these directions.
REMOVAL AND REPLACEMENT
LIGHTING AND TURN SIGNAL SWITCH
Removal and Installation
REMOVAL
(pic 1)
1. Remove steering column cover.
2. Remove screws (2), then remove lighting and turn signal switch from spiral cable.
3. Disconnect lighting and turn signal switch connector.
INSTALLATION
Installation is the reverse of removal.
Nov 16, 2018 at 9:17 PM
