Indicators/hazards not working
2004 FORD EXPLORER SPORT TRAC
160,000 MILES • 2WD • AUTOMATIC
BRIAN PATRICK CULLEN
The bulbs are good, the fuses are good, and I replaced the flasher relay, however; the problem persists. When I activate the turn signal, the icon does not show and there is no ticking sound. Any advice?
Jun 28, 2019 at 2:35 PM
BMDOUBLE
  • 1,139 POSTS
Try this: press the hazard switch several times then try the turn signals again. Usually the turn signal/multi-function switch goes bad and needs replacement. Over the years dirt and grime, dash cleaner etc. Find their way down in through the hazard switch cavity and cause a bad contact situation, along with normal wear and cause the switch to fail. Let us know what you find!
Jun 28, 2019 at 7:45 PM
I appreciate the response! I replaced the multifunction switch with a new one, still no luck.
Jul 5, 2019 at 7:34 AM
Do you have power at fuse #f1.34? this is what powers the flasher. here is a blinker wiring diagram so you can see how it works and a guide to help you check for power at the fuse with the fuse location as well:
Check out the diagrams (below). Please run this test and get back to us.
Jul 8, 2019 at 11:00 AM
