Indicators not working properly
2009 BMW 318
70,000 MILES • 0.7L • 4 CYL • TURBO • 2WD • AUTOMATIC
BERETTA 9MM
How do I make the turn signal flash more than three times?
Oct 10, 2019 at 12:14 PM
STEVE W.
  • 15,113 POSTS
There should be two positions for the turn signal stalk in each direction. There is a lane change that flashes the lights three times and then off. This is activated by just touching the stalk and gently pushing it to the first stop in either left or right. Then there should be a second position where the lever locks into position either left or right and holds the signal on until you either turn it off or if you make the turn it will self cancel.
If you can lock the turn signal switch in say the left turn position but it still only flashes 3 times it is most likely that you need to replace the multi-function switch.
Oct 10, 2019 at 1:57 PM
BERETTA 9MM
Hi Steve, it was the lane changing flashing I wanted to stay on a bit longer, I thought it extended through a computer. thank you for getting back to me so quickly. if I have any problems in the future I have your email address. once again many thanks.
Oct 18, 2019 at 3:36 PM
STEVE W. is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 18, 2019 at 3:37 PM
