INDICATOR CODES: CODE P0730 AND CODE P1456
2003 ACURA TL
99,000 MILES
DFERGUSON2013
Lost of power then the engine light came on, was able to shut engine down and restarted then car was drivable for about a few miles at very low speed; could not speed up; car starts up but not drivable now. Placed on a scanner and two codes came up: CODE P0730 AND CODE P1456.
May 23, 2013 at 8:16 AM
KHLOW2008
  • 41,814 POSTS
P1456 is most probably due to a loose fuel cap. Check it for proper seating.
P0730 is a problem with the shift control. Diagnostics would have to be carried out to locate the source. If solenoids are tested good, transmisison might have to be replaced.
May 23, 2013 at 1:08 PM
