turning the key to start the truck, I hear a click and nothing else?
1997 NISSAN TRUCK
189,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
EMRBAMA
After turning the key to start the truck, I hear a click and nothing else. Sometimes, it starts fine on the first try, sometimes it clicks then I try 1 or 2 or 3 or 4 times until it starts. Once it starts it idles fine and is good to go. The engine is not cranking over.
Nov 29, 2023 at 6:38 AM
This is common when you have a bad connection at the battery or the starter motor is going out, but to be sure let's check the battery cables first.
This guide can help:
If the cables are okay, use this guide to check for power at the trigger wire when the key is in the crank position:
https://www.2carpros.com/articles/starter-not-working-repair
Please go over these guides and get back to us.
Nov 30, 2023 at 1:04 PM
