I just changed my water pump this morning because it was leaking. After I put the new one on, I put water in to see if it was leaking. It didn't leak at the water pump anymore. Now it leaks from the back of the engine somewhere. I let it run for a little bit to see if it was overheating still. Which it did. I also noticed smoke coming from the object behind the throttle body. I could also hear a sound like it was boiling water under the throttle body, so I cut it off and the water shot out from where ever it's leaking from now. I was told it could be my heater core because my passenger side floor board stays wet and it fogs up from time to time.
Jan 30, 2020 at 3:40 PM
