Sudden no crank no start issue
2000 BMW 323
198,000 MILES • AUTOMATIC
BAMFB909
Car just wont crank, wont start all of the sudden. I have already checked everything I think it could be. Any suggestions as to what I should do now?
Jan 6, 2020 at 5:56 PM
STEVE W.
  • 15,113 POSTS
That could be caused by a few items. One would be a bad key, do you have another to try?
There are a couple fuses you can check, Fuse F14 and F67 both power the EWS.
Next would be a failure in the key detection parts, the ring antenna or the EWS control module. Testing those requires a dealer level scan tool that can read the security system data and allow testing of the system. Unfortunately BMW has made their system so that it is very difficult for anyone to work on the security system, The EWS requires programming through a dealer to get it to work and you cannot install a used part, the EWS has to be new.
Jan 6, 2020 at 10:21 PM
