Immobilizer fault, car cranks over will not start
2005 HYUNDAI GENESIS COUPE
75,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
MINIDISC7
As above the car will crank over but will not start.
image of a car with a key through the middle of it illuminates on the dashboard blinks three times and goes out.
Also, the central locking has stopped working.
If anyone has any ideas I would be very happy to hear them. many thanks in advance. Mark
Jan 15, 2018 at 2:03 AM
KHLOW2008
  • 41,814 POSTS
If the non starting occurred immediately after the central locking system stopped working, the problem is most probably related and could be due to a blown fuse for the security system.
Start with a check on the fuses and replace if any found bad.
Jan 15, 2018 at 9:17 PM
MINIDISC7
Many thanks for the reply. this check has been done and no fuses were found to be blown, the other work carried out was to have both keys and fobs checked by an auto locksmith and he confirmed that the transponders in the keys were operating as they should.
Jan 16, 2018 at 12:30 AM
KHLOW2008
  • 41,814 POSTS
Initial checks passed means we have to go further up the chain to diagnose the problem and locate the source.
The link above explains how to go about looking for causes and what should be present when getting the engine to start.
Let us know what you find.
Jan 16, 2018 at 9:34 PM
MINIDISC7
Many thanks again, I'll study the link and refer back to you, Cheers
Jan 17, 2018 at 4:02 AM
Jan 19, 2018 at 11:30 AM
