I found it, but I called my nearest Mitsubishi dealership said they don’t have a pin for the S/N I provided.
Jun 10, 2022 at 12:19 PM
SQM
CERTIFIED EXPERT
Usually, dealerships can look up part numbers by the VIN. Have you tried that?
Jun 10, 2022 at 12:55 PM
LIFEISKRAZY
MEMBER
Update: I was able to get the override code, but the car still won’t start. Fuel pump sounds like its working, the starter is cranking, I just tried spraying starter fluid into the throttle body and it’s not turning over. Next step is to check for spark I’m assuming? Sorry I’m new to this and learning as I go, lol.
Jun 10, 2022 at 1:09 PM
SQM
CERTIFIED EXPERT
If the engine is cranking over but not starting it is typically due to no spark or fuel. Since you are unable to start it with the starter fluid, checking for spark is the next best step.
Let me know what you find.
Jun 10, 2022 at 1:13 PM
LIFEISKRAZY
MEMBER
Got no spark, where should I go from here?
Jun 10, 2022 at 3:00 PM
SQM
CERTIFIED EXPERT
No spark can be due to a faulty coil/ignition module. See attached.
Another possibility is a faulty crank position sensor.
Jun 10, 2022 at 3:53 PM
LIFEISKRAZY
MEMBER
Ignition coil replaced and still no spark and now my security light is gone. I’m clueless on what to do now.
Jun 27, 2022 at 9:10 AM
SQM
CERTIFIED EXPERT
Are you getting any codes?
Crank sensor could be the culprit here.
You did mention that the immobilizer is not the issue right?
Jun 27, 2022 at 2:18 PM
LIFEISKRAZY
MEMBER
No codes crack sensor is fine. Ended up taking it to a dealership and even tho I replaced the ignition coil then want to put a another new one in because the one current is overloading on voltage. What do you think?
Jun 30, 2022 at 11:17 AM
SQM
CERTIFIED EXPERT
It the coil is overloading it will need to be changed, possibly a defective one. Are you able to get a warranty on the coil?
