Can the Immobilizer be repaired?
2024 NISSAN ALMERA
150,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
DPD ALMERATINO
Can it be repaired? Nissan Almera Tino 2,2 DCI 112 hP.
Oct 4, 2024 at 1:41 AM
Anything can be repaired; what problem are you having? Security light flashing? If so, I would disconnect the battery overnight and then reconnect it. This should reset the system. If not, you can try a hard reboot. Here is how:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Oct 4, 2024 at 12:45 PM
DPD ALMERATINO
Thanks, I think I'll do it!
The question of whether the computer is a Bosch! Because my mechanic claims that nothing can be done with the immobilizer and there is no way to turn off the red key on the dashboard!?
Oct 5, 2024 at 3:06 AM
That is incorrect. There is always a way to fix the car, that's why I like them. We should run a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Oct 5, 2024 at 9:45 AM
