My engine has low compression in cylinder 3 but I think in also cylinder 2.
The engine has rattling sound.
Low power. Poor performance.
Check engine light.
Heats fast at the half way mark in under 10 minutes.
Loses coolant quickly.
I'm thinking it is due to the timing chain. And I am curious to know if it my timing chain and timing tensioner that needs to be replaced.
I'm in question about how much that will cost me and exactly what other parts need to be replaced as well during that repair.
Toyota reported to me on my last oil chain that my engine has an oil leak in the timing belt cover seal.
Then shortly after all of that I began having these issues.
However before that. I had always had issues with my coils replacing them and the check engine light coming on.
It seemed to progressed since.
So I'm stuck between replacing the engine with a re-manufactured. Or used engine.
Fixing the issues with my current engine and replacing whats needed
Or not really sure where to take it to get an exact idea of whats actually needs to be replaced and the condition of the engine internally.
Thank you sorry if that was long and if you have any questions please call me
Thanks again.
Check engine light.
Thanks again.
Sep 22, 2019 at 5:57 AM
