Replacing the spark plugs isn't going to fix what you described. I don't know where you are located, but white smoke could simply be steam if the outside temperature is cool. If it continued and was excessive, then I would suspect coolant was getting into the combustion chamber due to a head gasket. If you said the white smoke came from under the hood, that would be different. If it's out of the exhaust, that is different. Take a look through this link. There is a section discussing white smoke. Take a look and see if it mirrors what you experienced.
Also, diagnostics would certainly be a good idea. See if there is a code that will point us in the right direction.
Veronica, I remember the trouble you had with the rack and pinion. I don't know the overall condition of the vehicle, but I'm starting to question if you will be able to get ahead of the problems. Since you've been coming here, I feel more like you're a family member. LOL And I don't want to take the chance of misdirecting you.
The reason I say about the overall condition is because of the transmission issue you mentioned. If the RPMs are increasing and the vehicle isn't speeding up, it sounds like it is slipping. With a CVT, that usually requires replacement. As far as replacing the fluid, a CVT is different than traditional transmissions, so unless you told me it smelled burnt and was very dirty, you would be fine.
Do me a favor. Video it is starting so I can hear it and see the tachometer. Also, if possible, record what it is doing when driving it. It's as close as I can get to a test drive unless you're in Pittsburgh. LOL
Another question I have is what rubber hoses were repaired with electrical tape? If they are vacuum hoses, that can cause a high, rough idle. Have you checked for leaks? Here is a link showing how:
When you start it and it sounds loud, does it seem like an exhaust leak?
Let me know and take care,
Jan 30, 2022 at 5:11 PM
