You may have crossed the wires and they are not going to the right cylinders. I attached a picture of cylinder location and the firing order. Make sure that is correct. The firing order is:
Firing Order 1-4-2-5-3-6
Also, did you gap the spark plugs prior to installing them? Are any of the spark plug wires laying on the exhaust manifold which may cause them to melt and arc?
If you feel confident that the order is correct and plug gap was correct, you may have damaged the plug wires when removing, they may not be all the way on, or you may have disconnected a vacuum supply component or something on the air tube, so check that too.
Feb 16, 2019 at 11:44 PM
