Ignition tumbler replacement
1994 GEO PRIZM
170,000 MILES • 2WD • AUTOMATIC
DREV0012
  • 36 POSTS
Hello, would you be able to walk me through replacing an ignition tumbler in the car listed above? The key will go in, but will not turn even to the accessory position and is very difficult to pull back out. Thanks!
Jan 25, 2017 at 11:42 AM
HMAC300
  • 48,601 POSTS
it says to remove ignition switch, but before doing that try it without removing switch see pictures. make sure to disconnect battery before attempting air bag removal.
Jan 25, 2017 at 12:05 PM
