ignition switch wiring harness, can I get a picture of the back of the ignition switch?
2004 NISSAN MAXIMA
176,000 MILES • 3.5L • V6 • AUTOMATIC
BRANDYBMB78
  • 12 POSTS
Can someone please send me a picture of the back of their ignition switch? I need to see the wires and how they are placed in the female end of the connector.
May 23, 2024 at 1:27 PM
STEVE W.
  • 15,113 POSTS
Nissan doesn't show the switch in their connector layouts in a color diagram, however using an image and the diagram we can show the connections. If you look inside the switch, it should also show the connection points. Hope that helps.
May 24, 2024 at 9:15 AM
BRANDYBMB78
  • 12 POSTS
going to try it, thanks.
May 25, 2024 at 5:37 AM
STEVE W.
  • 15,113 POSTS
The only hard one is that they used Black with red for both the starting and the ignition. Probably the easiest way to figure those out would be to apply battery power to each one and the one that turns the starter motor goes to the S terminal in the middle.
May 25, 2024 at 6:39 AM
BRANDYBMB78
  • 12 POSTS
still not doing right going to swap the red/blk and see if that works. thanks, a lot.
May 27, 2024 at 2:45 PM
BRANDYBMB78
  • 12 POSTS
I can't see if the labels are there hard to get under there to check just been guessing no luck.
May 27, 2024 at 2:48 PM
STEVE W.
  • 15,113 POSTS
Yeah, I don't know why they used the same colors to do two different things. Makes no sense but Nissan does things like that.
May 27, 2024 at 3:04 PM
BRANDYBMB78
  • 12 POSTS
still cant get it to do right is there something else I can do or try my gauges arent working now checked all fuses they r good
May 28, 2024 at 7:19 AM
STEVE W.
  • 15,113 POSTS
What is the original problem? Bad switch? Burned connection?
May 28, 2024 at 1:27 PM
BRANDYBMB78
  • 12 POSTS
I'm not sure how do I tell if it is a burned connection.
May 30, 2024 at 10:44 AM
BRANDYBMB78
  • 12 POSTS
also, since this I'm having to press the safety unlock switch to shift in gear. Why is this every time?
May 30, 2024 at 10:45 AM
BRANDYBMB78
  • 12 POSTS
Can I take the 2 screws out of this piece on the ignition to remove that part for easier access without any other problems?
May 30, 2024 at 10:47 AM
STEVE W.
  • 15,113 POSTS
So, what is the original problem? You cannot shift out of park with the car stopped? The screws hold the switch together, don't remove them.
May 30, 2024 at 5:05 PM
