Could you please explain the easiest way to replace a ignition switch? (Tilt steering wheel) Does the dimmer switch have to be removed first? If so,how do you remove it? It does not seem to have any screws hooked to it. I am assuming the reason my car is not getting any spark is a faulty ignition switch. I hooked 12 volts to the distributor and it starts up. Do you think I made the right diagnosis?
Jul 19, 2018 at 3:25 PM
