Ignition switch relay
2003 CADILLAC CTS
170,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
L B DANIEL
Where is the ignition switch relay on the 2003 Cadillac CTS?
Mar 14, 2016 at 2:52 PM
HMAC300
  • 48,601 POSTS
it's in the under hood fuse block. It should have a diagram on underside cover of fuse block.
Mar 14, 2016 at 4:04 PM
Hi here is a diagram of your PDC
Please let us know what you find
Mar 14, 2016 at 5:06 PM
L B DANIEL
Does anyone have a wiring diagram for the 2003 Cadillac CTS ignition?
Mar 16, 2016 at 11:35 AM
HMAC300
  • 48,601 POSTS
before we send a diagram what exactly is wrong with your car? won't start? try security reset first. or tell us what problem you are experiencing.
Mar 16, 2016 at 12:20 PM
L B DANIEL
Security test done 30 minute learned done starter, starter relay checked switch, checked no start, no crank, but security light goes out. I notice the switch is hot which leads to a negative ground or broken wire.
Mar 16, 2016 at 12:29 PM
HMAC300
  • 48,601 POSTS
it might be a bad switch too as they go bad.what I'm sending is what we have which is part of engine performance yellow wire is crank and pink is to coils. It could also be a bad connection in fuse box under the hood.
Mar 16, 2016 at 1:33 PM
