Engine will not crank or start, Ignition switch pass key 3?
2002 OLDSMOBILE AURORA
130,000 MILES
TIMOTHY WAYNE DAVIS
  • 24 POSTS
Car won't start or crank. Battery is hot all fuses good wiring appears okay. I tried to relearn the key. No help. Ignition has power. Acc and run positions working. There is a theft fault on the DIC. Starter works. I jumped starter relay with key in run position. It fired right up then shut off when I pulled jumper wire. The ignition switch looks fine inside and out it won't crank or start. Does anyone have a wiring diagram of the wires going to ignition and going out?
Aug 11, 2023 at 2:26 AM
TIMOTHY WAYNE DAVIS
  • 24 POSTS
Aug 11, 2023 at 2:31 AM
When you try to crank the engine over does the security light flash? If not, the system is not enabled. Here is the ignition switch wiring diagrams and a guide to help check for power:
Aug 11, 2023 at 3:24 PM
TIMOTHY WAYNE DAVIS
  • 24 POSTS
I've been starting the car by jumping the relay to power. I'm pretty sure the signal wire going to the starter solenoid is bad or shorted. Since I don't use the car that often and since the starter is under the intake, I haven't fixed it. Now I can get it to turn over it starts then shuts off immediately. I'm getting theft system fault on the dic. I've cleared all codes and ret but as soon as I hook battery up it gets the fault and will not start.
Oct 16, 2023 at 9:12 AM
So, I have seen the theft deterrent exciter wire break at the ignition switch, here are the wiring diagrams for it so you can see what I am talking about. Check out the images (below). Please let us know what you find.
Oct 16, 2023 at 9:56 AM
TIMOTHY WAYNE DAVIS
  • 24 POSTS
Thank you for the diagrams. I've tried 3 different exciter rings and tried several different. Starter switches. I got a new key that didn't work either. I suppose you're referring to the three-wire connector the exciter plugs into. I will change that and the wires and let you know what happens. One other thing is the orange wire that remains hot all the time going to the ignition when I turn the ignition to crank my test light goes out until I release it back to run position. I wasn't sure if it's supposed to do that.
Oct 18, 2023 at 12:39 AM
The orange wire should be hot at all times, is the battery in good shape?
Please go over this guide to be sure:
Oct 19, 2023 at 10:45 AM
