I have replaced the ignition switch multiple times because every time I go install the switch and try and crank over again on my power back to the car but as soon as I crank it over it shuts off. No fuse is blown. Before I had the issue with the ignition fuse blowing and it was the previous owner who installed the stereo to the ignition wire and was causing a short. Took the stereo out replace the fuse car worked again for a couple days and then shuts down when I try to crank it. Could the park neutral switch give too much voltage to the ignition switch causing it to go bad every time?
Aug 14, 2020 at 8:22 PM
