Ignition switch does not turn and steering wheel is locked.
Jun 21, 2017 at 7:07 PM
HARRY P
CERTIFIED EXPERT
Sometimes the steering lock mechanisms can bind up the ignition and keep it from turning. Turn the wheel in whichever direction the front wheels are pointed as hard as you can and try turning the ignition. Let us know if that works, or if you have already tried that.
I already tried your suggestion and it did not work. I also sprayed lubricant in the key hole and tapped the key/ignition-switch with the same results. The key did not turn and the steering wheel did not release. Any other suggestion? Thank you for your cooperation!
Jun 21, 2017 at 11:47 PM
HARRY P
CERTIFIED EXPERT
I guess you have probably jiggled the wheel back and forth and tried turning the key too. I will see if I can think of anything else to try.
Jun 22, 2017 at 3:04 PM
CERTIFIED EXPERT
It sounds like the tumbler has gone bad which is common for your cars age. You can get the replacement from Amazon for about $60.00
