Ignition switch replacement
1997 FORD F-150
1,999,999 MILES • 4.6L • V8 • 2WD • AUTOMATIC
DRIFTER41
  • 5 POSTS
I lost my key. I want to sale my truck but can't without a key. How do i take the cylinder out and will it work with a replacement? Not from the Ford house.
Jan 28, 2022 at 10:11 AM
SQM
  • 6,383 POSTS
You can get a key cut from your local dealer. Another option would be to have an automotive locksmith cut a key.
Either option you will likely need to provide proof of ownership, so they can make the new key.
You should not have to remove the lock cylinder. As they can make the key using the information from the VIN of that truck.
Thank you
Jan 28, 2022 at 11:20 AM
DRIFTER41
  • 5 POSTS
Won't work. I only have ownership by abandonment. How can i get that y cylinder out?
Jan 28, 2022 at 11:41 AM
SQM
  • 6,383 POSTS
You will have to remove the steering wheel to access the lock cylinder.
See the diagrams below.
Jan 28, 2022 at 11:46 AM
DRIFTER41
  • 5 POSTS
Yes, thank you. This will not affect the truck? It doesn't have a chip, correct?
Jan 28, 2022 at 12:15 PM
SQM
  • 6,383 POSTS
You are welcome.
Yes, the key does not have a chip.
Jan 28, 2022 at 12:18 PM
DRIFTER41
  • 5 POSTS
Sean, what credentials do you possess that tells me you are qualified? I did what you said and now i have someone telling me how stupid it was because it has a chip.
Jan 28, 2022 at 2:38 PM
DRIFTER41
  • 5 POSTS
Sean... What credentials do you possess that tells me you are qualified. I did what you said and now i have someone telling me how it was stupid because it has a chip.
Jan 28, 2022 at 2:41 PM
Sean M is one of our best experts and has a lot of qualifications. I am not sure how qualified this other person is, but it appears Sean M is correct that the 1997 did not have a transponder key.
Not only is there no info in the online manual about transponder keys for 1997 which means it was not equipped, but I had a 1997 F-150 and it should have the standard key.
If you can get a picture of your key that will help. However, I suspect if you have a key that has a transponder in it, that is just because someone thought that you needed one and cut the metal part to fit your truck, but the chip serves no function.
So, your key may have a chip, but the truck does not require one.
I attached the chart below showing that there was just a standard key through 1998. Then the second picture is of a standard key which is what you should have. Then the last is of a transponder key.
Again, if your key looks like the last picture then I suspect that it was just because someone assumed that is what was needed.
Plus, here is a video that shows this as well. You can clearly see in the video that they have standard keys, and this is a 1998.
https://youtu.be/ASpQBLCOn8A
Hopefully this helps and if you have conflicting info, we would appreciate the proof that this other person is providing you because I thinking they are incorrect.
Thanks
Jan 28, 2022 at 8:00 PM
