Engine not running
2002 PONTIAC SUNFIRE
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SARVER3
  • 4 POSTS
Key got stuck in ignition cylinder. Changed out ignition with one from a Cavalier and the theft light came on. Car started for over a year and then quit.Took it to a mechanic where it miraculously started again. They put it on a machine and said the only thing they found is that the new key had a chip and we needed to bypass it which we didn't know how to do. It ran for a while and then stopped again. Replaced ignition without a chip and it still won't start. Just turns over. The theft light is on all of the time but supposedly the car doesn't have an anti-theft device.
Mar 29, 2019 at 4:57 PM
SCGRANTURISMO
  • 4,897 POSTS
The anti theft devise is programmed into your vehicle's Power-train Control Module (PCM) AKA, "computer". I believe that GM's anti theft system uses resistance to come up with a predetermined voltage. If the incorrect voltage reaches the PCM then the vehicle will not start. In order for your vehicle to start properly, you will have to have the key programmed to your vehicle's PCM by either the dealership or a locksmith. These are the only two businesses that can program the key. There is no bypass, and if there was we certainly would not make it public knowledge where a car thief could get a hold of it. I am sure you understand that. I hope this helps and please let us know if we can help in ant other way.
Thanks,
Alex
2CarPros
Mar 29, 2019 at 5:25 PM
SARVER3
  • 4 POSTS
The original key didn't have a chip. The cylinder we just bought did not have a key with it. We had one made by a locksmith and it is supposed to just be a regular key without a chip. We thought if we went back to the way it was in the beginning it should start.
Mar 29, 2019 at 5:41 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Just about every vehicle manufactured from 1996 on has a chipped key, or some sort of anti theft system built in it from the factory. If the ignition key is not programmed to match the vehicle's PCM, the vehicle will not start. There is no way around this. Let us know if there is anything else that we can help you with.
Thanks,
Alex
2CarPros
Mar 29, 2019 at 10:41 PM
SARVER3
  • 4 POSTS
Thank you. We're going to take it to the shop.
Mar 30, 2019 at 4:03 PM
Apr 2, 2019 at 11:57 AM
SARVER3
  • 4 POSTS
We took it to a different shop and than the one who told us it was the key and it turns out it was the ignition switch and didn't have anything to do with the theft system. Also a loose wire on the fuel pump, and bad spark plugs. It runs great now though! Thanks for your quick responses.
Apr 2, 2019 at 5:14 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Apr 3, 2019 at 10:09 AM
JEREMY36
My car has been stalling out for about a week then the other day it would not. start no crank no start.
Apr 3, 2019 at 10:10 AM (Merged)
This can be caused by the ignition system losing spark or the fuel system losing pressure. here is a guide to so you can get started checking:
Please let us know what happens, we are interested to see what it is.
CLINTDUFFNEY
my car started this morning but when i went to pull out of the drive way my car shut off and wont start it turns over just wont completely start could it be the fuel pump relay i need my car to get back and forth from work i thought it was cause the car was low on oil so i put some in and car still wont start and no shops by me can tell me whats wrong unless i get it to them but i cant drive the car
SATURNTECH9
  • 30,869 POSTS
Is the security light on solid or flashing with the key in the run position?ALso have you checked the fuel pressure and for spark?
CLINTDUFFNEY
Yes I checked everything was fine and the theft light is on when I first turn the key I used to have a smell of gas about a three months ago but the last two months I haven't smelt anything then today the car just stops I have people telling me it could be the fuel pump relay or I need a jump but I have power in the car and lights come on just car wont completely start I'm not a whiz about cars
SATURNTECH9
  • 30,869 POSTS
Take some carb spray and spray it in the throttle bodysee if it starts?
TWOBLUE30
Car was running fine, no indications of problems. Stop and turned off car. Washed it, started it for father to check things under the hood. Turned it off for a few minutes and tried to start it later and NOTHING. It is as dead as a doorknob! Tried to jump the battery unsuccessfully. What to do next? Starter? New Battery? Could it be a wet distributor? Thanks for any help to point us in the right direction!
MMPRINCE4000
  • 8,548 POSTS
If you washed the engine, then I would suspect an electrical connection.
Remove connectors and clean with electronics cleaner.
STKNIGHT
Engine Performance problem
2002 Pontiac Sunfire 4 cyl Two Wheel Drive Automatic
no start started of as intermitant have replaced crank sensor cam sensor and ignition module we have power to coil pack cam is turning but no spark
Apr 3, 2019 at 10:11 AM (Merged)
JDL
  • 16,098 POSTS
Hello, any codes? Both the white and orange wires should have a pulse, with engine cranking? Did you visually check for spark?
STKNIGHT
[quote:55df82e613="jdl123"]Hello, any codes? Both the white and orange wires should have a pulse, with engine cranking? Did you visually check for spark?[/quote:55df82e613]
Hi not sure how this site works but we found the problem the ignition switch cuts the power to the coil and ecm in the start position if you backfeed 12 volts to coil positive car will start thankyou for your time
Steve
JDL
  • 16,098 POSTS
Hi, sounds like you need a new switch?
JWL1023
my fiancée got into the car, she said it started then stopped. Now it will crank and crank but not start. New spark plugs, good battery, and new wires. when I crank it it will shake and shutter. it might be the fuel pump because I can usually hear it running when I turn the key on.
RACEFAN966
  • 5,029 POSTS
I would check the fuel pressure or have it checked. You do have spark?
JWL1023
I have rented an auto scanner from autozone. it returns with PO140 which is O2 sensor and PO171 "system to lean"
RACEFAN966
  • 5,029 POSTS
That won't make it not start. Clear the codes and if you would make sure you have spark and let me know what you find ok.
Q2JOSH
first issue on this problem, started with a bit of fustration then ran 2 blocks then died. lights stayed on. battery checked good. tried to start again didn't. same effects when i wait a bit and try starting it 3 times. feels like a gas problem, has gas and put extra. 1st runs for a second then dies, 2nd turns with some fustration then dies, 3rd not a chance of turning. no codes.
SERVICE WRITER
  • 9,123 POSTS
IF you suspect a fuel problem, try spraying some carb cleaner into the throttle body and see if it runs for a moment. You can keep spraying into it to see if it will run off the cleaner.
IF so, check the fuel pressure to see if it is in spec.
IF a fuel pump is suspect, put a funnel into the filler neck and listen for the pump hum while someone else turns the key from off to run ( not crank). You can sometimes rap on the bottom of the tank to jar it into working (for a short time).
2CP-ARCHIVES
  • 4,540 POSTS
I have a 2002 Pontiac Sunfire that wouldn't start after I got gas. It sounds like it is starting but won't turn over all the way. It started for a split second once and then died. If I push the gas as I turn the key, it won't do anything. Any suggestions for what this could be?
JDL
  • 16,098 POSTS
When you first turn on the key, no crank, can you here the fuel pump run for a couple seconds? You can use a gage and check fuel pressure. Engine cranking, did you visually check for spark at the spark plugs? You can have a helper crank it.
CORKY SMITH
driving along at freeway speed and car just stopped running.....tried to crank, restarted for a for a few seconds and then died...still cranks but will not restart any ideas ..... not out of gas
Check/monitor the fuel pressure if its withins specs-fuel pump could have failed-start here
2CP-ARCHIVES
  • 4,540 POSTS
my car was fine the other day. then i parked it and went for a walk . when i went back to my car it wouldn not start. i just had the oil changed a week before. i had a full tank of gas. and i had just had my cars water pump replaced a few weeks back and the mechanic said my car was fine. now my car wont start, it turns and makes a grinding turning noise the whole time. we tried to boost it and it still wouldnt start, we checkd the fuses and they were okey. what is the problem?
JDL
  • 16,098 POSTS
If the cranking system is ok. Have a helper crank it while you check for spark at the spark plugs. If you have spark everywhere, use a gage and check fuel pressure. Any applicable trouble codes? To check codes, yourself, at the least, you need an obd2 code reader. Your security system could cause an issue. You need to do a little testing to narrow things down a little.
SWIFT79
  • 4 POSTS
Electrical problem
2002 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
OKAY NOW......I replaced the socket and starter. NONE of my blinkers, brake lights or hazards work. Also my car wont start unless i use a frickin screw driver again. Is all this related? or what the hell is going on and what do I do or start and locations. All fuses are good too
BMRFIXIT
  • 19,053 POSTS
a bad or faulty multifunction switch(combination switch) maybe suspected here for the brakes and signals
no start much to suspect and have to check neutral safety switch
ignition switch
and wiring in between
NADAMS
2002 Pontiac Sunfire 6 cyl Two Wheel Drive Automatic
engine light been cutting on and for last two years.
head it check out problem corrected now car wont start
F4I_GUY
  • 3,302 POSTS
First step is to get that code read. That will lead you in the right direction with regards to diagnostics.
RUBY.GRAHAM
have a 2002 Pontiac Sunfire Sedan. We were driving home (w/ 3/4 tank of gas) and headed up a slight incline when all of a sudden the car stopped responding to the gas pedal and the power steering stopped. The electrical system was still responding and the engine was still running. We turned off the vehicle and tried turning it back on but it would not start. We towed it back to our house. My husband and father checked the fuel pump and it appears to be working. It acts like it wants to start but it won't turn over.
JDL
  • 16,098 POSTS
Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage. Hopefully, you have a schrader valve to hook the gage to. Don't take any fuel lines loose unless your sure there isn't any pressure on the system.
Check for applicable trouble codes, at the least, you need an obd2 code reader. How long since a tune-up?
GAIL.PATTON
Twice today, I needed a jump w/ cables to start my car - 2002 Pontiac Sunfire std trans - I don't think the battery is dead because i still had power to windows and locks and dome light. When I tried to start it, before the jumps each time, it tried to turn at first, then kind of like made this shissh followed by a rapid click sound, then nothing. I bought the car used in 2004, and have never replaced the battery. In fact, the car's run like a top since I got it. Well, except both windows won't come down past a 5 inch opening -- all I get is a loud ratcheting sound when I keep pressing the power window button down. the first one, driver's side, malfunctioned about a year ago. The passenger side just started doing the same thing this morning...
It sounds like the battery is weak and unable to crank the engine. It can have enough power to work the electrical items you mentioned, but the starter places the heaviest load on it. If it starts to crank and then clicks, the battery is too weak to start the engine.
Remove the battery, recharge the it and take it to have a load test done at a parts store. Most will do it for free. Once it is under a heavy load, my guess is it will fail.
Let me know what you find.
