security light is always on
1991 BUICK PARK AVENUE
100,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
SCOTTB10
  • 36 POSTS
When I was putting on the battery terminals the car started. I had the keys in my pocket so I was surprised. It's done it a couple times now. When I got in and put the key in, I turned it on first, then turned it off but it continued to run. Then I put my foot on the brake and it shut off. It starts and shuts off normally now. But I also have a couple other issues; the battery dies after a few days of not driving it and the security light is always on.
May 29, 2020 at 5:18 PM
Does the vehicle have a remote starter system? Also, have you tried to retrieve diagnostic trouble codes? This vehicle has an OBD1 system. A scan tool is not needed to get codes. All you need is a short jumper wire or even a paper clip. Here is a link that explains how to retrieve code. Lets try this and see if anything is stored that may help.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know what you find. Also, let me know if there is a remote starter that is on the vehicle and if it is a factory system or aftermarket.
May 29, 2020 at 10:01 PM
SCOTTB10
  • 36 POSTS
Thanks for the reply, I don't know if it has a remote starter. Raining big time today so I will do the code check tomorrow. I'll let you know the results.
May 30, 2020 at 2:57 PM
Sounds like a plan. Let me know what you find. Stay dry!!!
May 30, 2020 at 8:28 PM
