Did you replace the ignition lock portion? That's where the key goes. Or, did you replace the actual switch? Here are the directions for the switch. Let me know if this is what was done.
_________________________
Removal
See picture 1
1. Disconnect the battery ground cable.
See picture 2
2. Detach the hood latch release handle and position aside.
1 Remove the bolts.
2 Position the hood latch release handle aside.
See picture 3
3. Remove the lower instrument panel steering column cover.
1 Remove the screws.
2 Remove the lower instrument panel steering column cover.
See picture 4
4. Remove the instrument panel steering column opening cover reinforcement.
1 Remove the bolts.
2 Remove the instrument panel steering column opening cover reinforcement.
See picture 5
5. Disconnect the electrical connector.
1 Loosen the bolt.
2 Disconnect the electrical connector.
See picture
6
6. NOTE: The ignition key should be in the OFF position.
Remove the ignition switch.
2 Remove the ignition switch.
Installation
See pictures 7 - 10
1. Note: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn its strategy.
To install, reverse the removal procedure.
__________________________
Jan 12, 2019 at 9:28 PM
