ignition or fuel regulator/pump
2005 DODGE MAGNUM
144,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
WILLIE HURLOCKER
  • 83 POSTS
one of yall told me your mother inlaws dodge mini van was doing the same thing a while back. my wagons ignition when i turned would do nothing unless i let it turn back about half way then turn it back on & start. not every time about 2x in last 6 months! alright its still dying sometimes when i slow down to stop or turn into a parking spot & if i hurry & put it in D & start it it starts but goes to limp mode then i kill it put it back in p then wait 5 secs. start it & normally put it in D it drives fine! its done this 2/3 x past 6/7 months? could these to things be one or separate no codes well had one a couple weeks ago for p0420 cat slow response but cleared it & hasn't come back? thinks its the fuel pressure regulator/ pump or the ignition switch. crank & cam sensors are new. ive got a vac. pump but not the right connector.
Apr 21, 2024 at 8:12 PM
