Will not start
1998 VOLKSWAGEN CARAVELLE
234,896 MILES • 2.6L • 6 CYL • 2WD • MANUAL
JAMESKEKANA
  • 6 POSTS
Car will not start. tried starting it by push but suddenly nothing. what could be the problem? Ignition module and pick up sensor?
Mar 27, 2018 at 12:50 PM
F4I_GUY
  • 3,302 POSTS
First we need much more detail. Does it crank? Are there any faults stored? Have you tested for fuel and spark? Here is a great link that can assist you:
Mar 27, 2018 at 7:17 PM
JAMESKEKANA
  • 6 POSTS
yes tested fuel but no spark at all, but the coil is sparking very well. could it be the distributor?
Mar 28, 2018 at 3:41 AM
Yes it sounds like you have an ignition rotor that needs to be replaced. I hope this engine has one because the engine I see are all diesel?
Mar 30, 2018 at 12:01 PM
