Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Laser
Engine
Symptoms
Not Running
Will not start after replacing ignition leads
2001 FORD LASER
236,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
KELLY BLACKMAN
MEMBER
1 POST
FOLLOW
I have just changed the two ignition leads and now car will not start
Image (Click to enlarge)
Jul 31, 2018 at 12:52 AM
CERTIFIED EXPERT
Did it run with the old stuff? Can you remove one if the leads to check for spark? Here is a guide to help you test for spark look toward the bottom:
Aug 1, 2018 at 5:53 PM
