Take a look through this link and see if it helps. It discusses different ways to deal with a stuck key.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
If that does not help, confirm the shifter is fully in the park position. Shift back and forth a couple times to make sure. If that does not work, check the ignition fuses located in the power distribution box under the hood for a blown fuse.
Do these things first and let me know what you find.
Sep 21, 2018 at 5:56 PM
