ignition issues
1984 FORD F-250
165,000 MILES
RUG RAT
  • 6 POSTS
could a faulty coil cause my problems? i have never changed my coil since i changed my dist. from electronic to points. could my coil be the problem? if so please let me know and/or what should the volts/ohms be to and from my coil to the dist. (should i use a secondary resistor/condenser or not?)
May 3, 2013 at 5:31 PM
what is the exact issue???
May 3, 2013 at 6:13 PM
RUG RAT
  • 6 POSTS
i can drive my truck for about five or six miles and it starts to bog down and if i try to keep going it will eventually shut down, when that happens i have to get out and sand down my points and then it runs fine for another another five or six miles. what could it be?
May 3, 2013 at 6:20 PM
CARADIODOC
  • 34,306 POSTS
What kind of problem are you having? Why would you want to go back to miserable breaker points? Do you have a ballast resistor in series with the ignition coil and a way to bypass it during cranking?
May 3, 2013 at 7:30 PM
