Been reading a post between the medic and cfengineer. I have the same issue.
What i know so far:
Was running fine and just died
84 cj7
79 304 (I think)
Ford ignition not prestolite
New coil (external resistor)
New ignition module
New distributor
5v at coil with ignition on
11v at coil while cranking
Pulsing spark to ground from coil while cranking
Spark at number one plug only at first crank and when released
No spark during extended cranking
Fuel present
Timing close to correct
Ignition switch has been abandoned
In its place a switch for ignition and a momentary switch for start. Been working this way for years.
HELP
What i know so far:
84 cj7
79 304 (I think)
New ignition module
New distributor
Fuel present
HELP
Mar 26, 2017 at 1:54 PM
