Ignition issue
2002 CHEVROLET CAVALIER
155,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
COLE DAVIS WATSON
I am having trouble with starting my car. It feels like it would be some sort of switch behind the clutch because normally I push the clutch all the way down to crank the vehicle. Some times I do not press it down all the way and it just does not do anything at all. It feels like maybe that went out because now that I fully press on the clutch is does not do anything at all. I tried to take it to AutoZone and have them see if it was my starter and they told me it was something with my battery. After I bought a new battery, we come to find out it was not that at all. They never tested again to see if it was my starter. I am not sure how to see if it is maybe some kind of switch behind the clutch maybe? It is a manual. Not an automatic
Oct 30, 2018 at 7:01 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It might just be a failing clutch start switch. It is located under the steering column, under the dash. It feeds voltage to the "crank" fuse located in the under-hood fuse block so you could just test that "crank" fuse for voltage with the key on start and clutch pedal down. That may give you the clue you need.
Oct 30, 2018 at 8:32 AM
COLE DAVIS WATSON
I thought that too, but I cannot seem to find it underneath the pedal, I tried looking for it on a site like AutoZone for a replacement and they did not know what I was talking about.
Oct 30, 2018 at 10:54 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I do not have a diagram either, but that is where it is supposed to be.
Oct 30, 2018 at 11:36 AM
COLE DAVIS WATSON
So finally I ended up replacing my starter because it seemed likely and it was not that either. I was able to test the crank fuse as you said and it does seem to be working correctly with the key in and pedal down. I am not sure what else it could be.
Nov 11, 2018 at 1:04 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Make sure the BATT 2 fuse is not blown and if not, try a new starter relay.
Nov 12, 2018 at 7:39 AM
