ignition cylinder wiring diagram for build needed?
2000 CHEVROLET S-10
200,000 MILES
421JMS
  • 6 POSTS
I have the truck listed above that is being body converted, but i am using the stock s10 wiring harness and all components. Is there a chip in my key and if so, how would i be able to bypass that so i can use a custom switch plate for a push button start and all of that? This is going to be completely custom, but i want to keep it simple so i can do it myself. i have seen people say i need a resistor in the circut somewhere or that all i have to do is cut a yellow(?) wire on the back of the ignition. i am trying to get professional input before i go chop everything up. thanks
Jan 4, 2023 at 6:59 PM
STEVE W.
  • 15,113 POSTS
No chip in the key, that vehicle uses a Pass lock II system. It uses a common key but there is a sensor in the ignition lock housing that triggers when the magnet on the lock cylinder rotates to it. The sensor sends a signal to the body control module and the powertrain module, those are compared and if it's the correct signal the engine starts. This site might help you but I don't do any bypass methods, but you can try it if you like.
https://www.jaycorptech.com/tech/passlock.htm
Jan 4, 2023 at 10:23 PM
