ignition control module
1998 FORD CONTOUR
130,000 MILES • 4 CYL
BROOKLEE STIEF
Where is the ignition control module located
May 2, 2016 at 6:03 PM
there is a ignition control relay and a crankshaft angle sensor but the amplification of the ignition signal is done by the ECM here are the ignition wiring diagrams as you can look for yourself.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
Mar 28, 2017 at 8:29 PM
DAWN39JONESBORO
  • 6 POSTS
a crankshaft sensor exactly where is it at on a 98 ford contour i can't see it and i tryed looking it up in the books and it doesn't show
Mar 28, 2017 at 8:29 PM (Merged)
CATCH_15
  • 250 POSTS
There's only one place in can be. Look on the front of the engine by the crank pulley.
  • 0 POST
Does the 1999 Ford Contour SE, with the 2.5L Duratec engine, have an Ignition Control Module and if so, where is it located?
no, the spark is controlled by the crank sensor, pcm and coil.
TONI E
Engine Mechanical problem
1996 Ford Contour 6 cyl Two Wheel Drive Automatic
Location of ignition control module
BMRFIXIT
  • 19,053 POSTS
PCM
powertrain control module
behind power steering reservoir
ignition control module is a part of the PCM
pcm responsible for firing the coil
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
